HI, I’m new to Kicad. I like the suite. All in all it’s very functional with few quirks. The problem I’m having is the only hotkeys that work for me is W, G, and a few others. Any command that requires Shift, Alt or Ctrl do not appear to work.
I’ve scoured the help file and haven’t found an answer. Can anyone help?
Mine also shows the hotkey commands in grey.
And in order to select the tool “wire” I only press “w” without “shift”. Furthermore if I press “b” afterwards, nothing happens. I need to press “esc” to exit the wire mode and then press “b” to enter the bus mode.
But if I press “q” or “j” a no-connect flag or juntion dot are placed without the need of pressing “esc” before. Maybe it is in the documentation, but anyway it is an odd behaviour.
Doing some experimentation, pressing ‘A’ without Shift brings up the part library. This is true for Bus, Polyline and the rest of the commands. Mystery solved. I’ll just chalk it up to software quirks. Compared to OrCAD, this is really not a big deal.
