in the PCB editor, no matter hom much I type ’ to higlight a whole net it does not work
how do I fix this ?
thanks
how do I fix this ?
thanks
Are you actually typing ’
the quote mark? If so, it’s not working because the hotkey is actually `
(backtick)
actualy for me it is U for some reason
U
is a different action, it expands the selection of a track to other tracks on the same net that are connected. Selection and highlighting are not the same thing.
well highlight does not work, so I have to select
I tried rebinding the ’ to be sure, but nothing happens
The function works perfectly on this:
Version: 7.0.5-unknown-202306072352~d5cbb56160~ubuntu22.04.1, release build
wxWidgets 3.2.1
FreeType 2.11.1
HarfBuzz 6.0.0
FontConfig 2.13.1
libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.14
Platform: Linux Mint 21, 64 bit, Little endian, wxGTK, cinnamon, x11
Date: Jun 7 2023 23:52:37
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.88.1
ngspice: 38
Compiler: GCC 11.3.0 with C++ ABI 1016
KICAD_SPICE=ON
What is your Kicad version and OS, so others may check?
Application: KiCad x64 on x64
Version: 7.0.5, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: May 27 2023 02:48:13
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.6.3
Curl: 7.88.1-DEV
ngspice: 40
KICAD_SPICE=ON
What keyboard layout do you use? Can you confirm that you are using the backtick key, which is also the tilde key (~
) to the left of the 1 key on a US layout? You keep using single quote ('
) instead of backtick (`
) in your forum posts and I want to make sure you’re hitting the right key.
Beligan AZERTY
in PCB editor, nothing happens no matter what I try to highlight
I even try rebinding the keys, just in case, but they dont change so I am pressing the right key
What if you right-click on a track, go to Net Inspection Tools, then Highlight Net?
additional ideas:
A clearer view of the French Azerty:
Tilde is lower case super 2.
Backtick looks like lower case super 7, but I’m not sure as it is marked as a dead key (but so is tilde marked as dead )
Lower case 4 is a single quote, not a backtick as it matches the double quote on lower case 3.
A couple more thoughts
Although the lower case super 7 is blank on the Belgian Azerty, it may work.
Failing that, perhaps changing the keyboard to French Azerty (if not too insulting ) in Windows (if possible), may give access to that key.
If all else fails, change the “Highlight net” hotkey. Note: it is easy to miss the backtick symbol in the hotkey list, so make sure the monitor screen is clean.
Exactly!!!
Change the hotkey to a letter. There are a lot of hotkeys one never use. In my case I have h to highlight and shift+h to “unhighlight”
same as hitting the U key
yes all enabled
and CTRL+click works but only select a part of a track
Belgium is not France
is Canada the same as USA ?
and as mentioned, I rebound the keys in preferences to be sure
U works fine for me, as these very belgian keys
²²²²²
this is the upper left key → ²²²²²²
not only it works but it binds well in preferences/hotkeys
I tried binding other keys, same issue
what is that ?
Below is most of the English Qwerty 104 character keyboard.
The green arrow is pointing to the “Backtick” symbol. This is the hotkey assigned to “Highlight net” in Kicad.
The red arrow is the “Single quote” symbol you have been trying to use to “Highlight net”.
A green arrow is also pointing to the “Backtick” symbol on the French Azerty keyboard.
There is no “Backtick” on the Belgium Azerty keyboard.
I thought I considered this with:
EDIT: The idea of using Windows to change your keyboard to French Azerty was to see if the backtick hotkey on your keyboard (lower case super 7) performed the hotkey function “Highlight net” assigned in Kicad.
