Highlight Net in layout
Hi all.
Recently one of my designs went over two sheets.
I wanted to check if all connections were OK by highlight them.
I could not find out how to do do so.
If there is a way to do this can it be done over multiple sheets.
If there is no such facility can this be requested?
Regards
Francesco C
First, which version of KiCad are you using?
Second, in the subject line you mention “layout”. But then you talk about “multiple sheet” which refers to a schematic. Layout is the pcb, schematic is the electronic system diagram. Which one do you mean?
Hi, thank you for the reply.
Yes I clicked layout by mistake.
My version is 5.16.
Thanks
Francesco C
So do you mean that you want to highlight a net in the schematic, and see the same net highlighted in different sheets?
There’s the Highlight net tool:
Hi. Thank you again for kind reply.
Yes that what I was looking for!
I kept looking under the menus.
Thank you.
Francesco C
