is it possible to highlight all nets that belong to a given net class in the PCB Editor (KiCad v8.0.4)?
Thanks in advance ![]()
Simon
edit: KiCad Version
Simon
edit: KiCad Version
Yes, it’s possible.
First, go to the Appearance Mangager / Nets tab, then set Net colors to all, double click on the rectangle before one of your net classes and select a color for it.
This is great, thanks a lot! This will make my board editing much more efficient.
Another question: Is it also possible to select all nets from a net class? In my current design I need to change width of an entire class for impedance correction…
PCB Editor / Edit / Edit Track & Via Properties, and then use the **Filter items by net class.
If you want to set tracks to a specific with, you have to fill in the pre-defined widths first. But for:
It seems more useful to first set the net class settings themselves to the right value and then use the Set to net class / custom rule values option.
Thanks again, this also was a valuable hint.
I changed the solution from my second to my first post, because that is the answer to the original question. The goal of this solution thing is for people searching the forum to find answers quicker.
