High node count poly lines
I export my KICAD pcb’s into autocad lt to create a labeled assembly diagram. I export to a dxf and then import that to autocad.
Is there a way to get rid of the smoothing that KICAD does? every track and copper pour has smoothed out edges. This is fine in autocad but If i want to bring any of the artwork through to solidworks this slows solidworks down to a crawl.
I couldn’t find any threads about this or any options to change the way tracks and pours behave
Version 6 will have (and 5.99/nightly builds have now) different filling mechanism for zones which could help with zones. But not for traces.
I think it should, at least theoretically, be possible to replace those small straight segments with longer arcs when plotting. You can file a bug report if you want to and see what happens.
It’s a minor inconvenience at best. I’d like to make assembly drawings in solidworks but the dxf sketches bog down SW too much. It doesn’t sound like a complicated feature to add in. A text box as you export to dxf to disable trace smoothing and another for planes.
I’d try going through Freecad with stepup.
Or maybe through .svg (if autocad/solidworks can import .svg)
