Hierarchical sheet value variable
Hi all,
we have multi-channel OpAmp schematic as a hierarchical sheet. Now a couple R/C have different value, is it possible to substitute their value from a sheet’ variable.
Otherwise the whole sheet has to be duplicated multiple times, which is prone to error and introduces unnecessary work.
Is there such a feature I may have missed, or is something on the roadmap?
Best,
M
Sadly no.
You can also connect the components which need to change on the outside. See handling of HSEL in the hierarchical example of my FAQ article Hierarchical or flat schematic design, what is best for me? (How to deal with multi page schematics?) (one channel directly to ground, other channel via resistor to 5V)
That is a viable option, thanks for the reply and link!
Best,
M
https://gitlab.com/kicad/code/kicad/-/issues/2466
