Hi, I have a multi-channel schematic that I’m working on, and I’m wondering if what I’m seeing is normal behavior? I want to connect a net to the hierarchical pin that is imported from the sheet. From what it looks like, the net isn’t actually connecting to the pin, as I still see the little square by the pin, as seen in the first photo below. If I route a wire to the pin and click on the pin, the wire tool doesn’t actually terminate the wire either, I have to double click to end the wire.
I want to make sure that I’m actually connecting these in the netlist. What’s weird too is if I move the pin to the other side of the sheet symbol then it connects just fine and the little square goes away. (I can’t upload that image as I can apparently only place one image in a post as a new user)
Is this expected behavior? Thanks for your help!
