I was able to get a set of identical hierarchical sheets to layout identically to my initial layout with the replicate layout plugin. Fantastic, MitjaNemec! Really spectacular time saver. Thank you!
As a bit of help for those that haven’t tried this it was pretty straight forward:
draw in a single hierarchical sheet and then layout one replica of the circuit to be replicated.
Make a sheet for each replicant, use the same file name but different sheet name. It will kindly offer to link the sheets rather than destructively overwrite the file named.
Make a netlist, annotate, import the new netlist.
Git the downloads: https://github.com/MitjaNemec/Kicad_action_plugins
put them in the Program Files\KiCad\share\kicad\scripting\plugins\replicate_layout directory if you’re using windoze
From the already laid out section, select an anchor point, pivot, whatever you want to call that spot around which the layout will replicate. go to tools > External Plugings > replicate layout (refresh if it’s not there, else check the directory you put the plugins into. Kick off the plugin and select the revelant sheet and viola!
anyway, back to the main question, which will surely betray me as a noob:
After I was able to make my replicants in both schematic and layout I wanted to pull a net from each replicant sheet and send them individually into another unrelaed sheet. You have to be really careful here, anything that goes into one sheet goes to all the replicants. So I named a pin “Phase” in each replicant hierarchical sheet, and then was expecting to be able just connect those with out too much difficulty, I tried two different ways and each time the replicants were forced to the same net name on the pins and strangley they didn’t connect to the replicant location:
I don’t get how you’re supposed to get individual nets out of replicated layout, it seems to force the pins of the replicants (Hierarchical sheets sharing the same file) to the same .
What am I missing here?
This is all in Kicad 5.1.2
Thanks,
Bill
