I sometimes “misuse” KiCad for producing generic schematics, like analog filters, flip-flop circuits and so on. Simply because I like KiCAD and it’s easy.
This needs generic symbols, which are not always available in the general library, so I select an existing one for doing the generic schematic.
Removing the reference and the value is easy.
I’m sorry, apparently my question was unclear.
I’m not talking about resistors etc., but about D-flipflops, JK-flipflops, counters, opamps, etc., where there are no generic symbols.
Instead I use the symbol of a 4013 D-flipflop for example, and hide the reference/value. But the pin numbers persist.
How do I hide those?
As the schematics will be used in a document in the end, I’ve exported them and removed the pin numbers in a graphic editor, before inserting them into the document. I just wondered if there is an easier way.
To get to this dialog, open a symbol i the symbol editor and then edit it’s properties.
Symbols Editor / Edit / Properties
Also, if you do such things you have to be aware that KiCad’s own libraries are read-only. This means you also have to learn some library management. I suggest you first make a project specific library, then copy the symbols you want to modify into it and then modify them to your hearts most secret desires.
