I need several holes with complicated shapes (hexagon, etc.) with metalisation. I tried to make a component and generate gerber according to this component. However, jlcpcb do not want to manufacture it without reasonable explanation.
Since I am new user, I cannot upload here, so I just put plain text of my *.kicad_mod file below.
Thank you
Ilghiz
(module Inject-1 (layer F.Cu) (tedit 58EAE0ED)
(descr “Inject-1”)
(tags “Inject-1”)
(attr smd)
(fp_text reference REF** (at 0 0) (layer F.SilkS)
(effects (font (size 1 1) (thickness 0.15)))
(fp_line (start -3.7 0.0) (end -1.9 3.2) (layer Edge.Cuts) (width 0.1))
(fp_line (start -1.9 3.2) (end 1.9 3.2) (layer Edge.Cuts) (width 0.1))
(fp_line (start 1.9 3.2) (end 3.7 0.0) (layer Edge.Cuts) (width 0.1))
(fp_line (start 3.7 0.0) (end 1.9 -3.2) (layer Edge.Cuts) (width 0.1))
(fp_line (start 1.9 -3.2) (end -1.9 -3.2) (layer Edge.Cuts) (width 0.1))
(fp_line (start -1.9 -3.2) (end -3.7 0.0) (layer Edge.Cuts) (width 0.1))
(fp_line (start -4.0 0.0) (end -2.0 3.5) (layer F.Cu) (width 1.0))
(fp_line (start -2.0 3.5) (end 2.0 3.5) (layer F.Cu) (width 1.0))
(fp_line (start 2.0 3.5) (end 4.0 0.0) (layer F.Cu) (width 1.0))
(fp_line (start 4.0 0.0) (end 2.0 -3.5) (layer F.Cu) (width 1.0))
(fp_line (start 2.0 -3.5) (end -2.0 -3.5) (layer F.Cu) (width 1.0))
(fp_line (start -2.0 -3.5) (end -4.0 0.0) (layer F.Cu) (width 1.0))
(fp_line (start -4.0 0.0) (end -2.0 3.5) (layer B.Cu) (width 1.0))
(fp_line (start -2.0 3.5) (end 2.0 3.5) (layer B.Cu) (width 1.0))
(fp_line (start 2.0 3.5) (end 4.0 0.0) (layer B.Cu) (width 1.0))
(fp_line (start 4.0 0.0) (end 2.0 -3.5) (layer B.Cu) (width 1.0))
(fp_line (start 2.0 -3.5) (end -2.0 -3.5) (layer B.Cu) (width 1.0))
(fp_line (start -2.0 -3.5) (end -4.0 0.0) (layer B.Cu) (width 1.0))
(fp_line (start -4.0 0.0) (end -2.0 3.5) (layer F.Mask) (width 1.0))
(fp_line (start -2.0 3.5) (end 2.0 3.5) (layer F.Mask) (width 1.0))
(fp_line (start 2.0 3.5) (end 4.0 0.0) (layer F.Mask) (width 1.0))
(fp_line (start 4.0 0.0) (end 2.0 -3.5) (layer F.Mask) (width 1.0))
(fp_line (start 2.0 -3.5) (end -2.0 -3.5) (layer F.Mask) (width 1.0))
(fp_line (start -2.0 -3.5) (end -4.0 0.0) (layer F.Mask) (width 1.0))
(fp_line (start -4.0 0.0) (end -2.0 3.5) (layer B.Mask) (width 1.0))
(fp_line (start -2.0 3.5) (end 2.0 3.5) (layer B.Mask) (width 1.0))
(fp_line (start 2.0 3.5) (end 4.0 0.0) (layer B.Mask) (width 1.0))
(fp_line (start 4.0 0.0) (end 2.0 -3.5) (layer B.Mask) (width 1.0))
(fp_line (start 2.0 -3.5) (end -2.0 -3.5) (layer B.Mask) (width 1.0))
(fp_line (start -2.0 -3.5) (end -4.0 0.0) (layer B.Mask) (width 1.0))
(pad 1 smd circle (at -4.0 0.0) (size 1 1) (layers *.Cu *.Paste *.Mask))
(pad 1 smd circle (at -2.0 3.5) (size 1 1) (layers *.Cu *.Paste *.Mask))
(pad 1 smd circle (at 2.0 3.5) (size 1 1) (layers *.Cu *.Paste *.Mask))
(pad 1 smd circle (at 4.0 0.0) (size 1 1) (layers *.Cu *.Paste *.Mask))
(pad 1 smd circle (at 2.0 -3.5) (size 1 1) (layers *.Cu *.Paste *.Mask))
(pad 1 smd circle (at -2.0 -3.5) (size 1 1) (layers *.Cu *.Paste *.Mask))
