I am looking to design a PCB to connect the electrodes from two camera parts. I’ve never done this before so I’m a bit lost, and I was referred to this site by a PCB manufacturer that I contacted. The camera is a DJI Action 2 camera, and there are two modules. Normally they’re positioned above each other with their electrical connections in contact per the original design, but I’d like to position the battery unit behind the camera unit, and so I need a PCB to connect the two. See the attached pic. Would anyone be able to help with this, and what type of pin connectors would I need for the PCB?
Thank you!
