Help with FreeCAD StepUp - Microwave Layouts
I have an ADS momentum design for a Wilkinson splitter and wish to turn it into a copper zone on my board. I don’t want to import artwork and manually draw it because it will introduce possibly detrimental errors with the loss in precision.
I have been playing around with the KiCADStepUp tool in FreeCAD, but I can’t get anything usable. I’ve been trying for hours. Please help!
The Antenna example is great and all I’d need; however, there is very little documentation nor a step by step procedure that isn’t either extremely outdated or incorrect. Do you have to name the sketch something specific for it to work when converting to kicad footprint? When I name it Pads_Poly after converting the dxf into a sketch I get the following error:
15:55:19 PoM not present
15:55:19 using ‘Part’ container and ‘Links’
15:55:19 FC Version 019-24291
15:55:19 kicad StepUp version 10.1.7.0
15:55:19 tolerance on vertex applied
15:55:19 applying Materials to Shapes
15:55:19 your home path is /Users/michaeleller
15:55:19 export to STEP False
15:55:19 Tabified done !
15:55:19 done!
15:55:19 need to discretize Arcs
15:55:19 Running the Python command ‘ksuToolsFootprintGen’ failed:
Traceback (most recent call last):
File “/Users/michaeleller/Library/Preferences/FreeCAD/Mod/kicadStepUpMod/kicadStepUpCMD.py”, line 2114, in Activated
kicadStepUptools.PushFootprint()
File “/Users/michaeleller/Library/Preferences/FreeCAD/Mod/kicadStepUpMod/kicadStepUptools.py”, line 16217, in PushFootprint
sk_d=Draft.makeSketch([wns,wnc[0]], autoconstraints=True)
list index out of range
I just need to turn a complex shape from a dxf into a copper zone – doesn’t even need to be a footprint necessarily.
Here is the general artwork shape
OK. FYI:
You can export the artwork from ADS as a gerber plot, open with kicad’s gerbview, and export to new PCB.
That’s what I’m going with for now.
would you mind to post the dxf file?
Looks like I’m a “new user” and can’t upload files :frowning:
@hermit or some admin could help @mbe9a in ‘new user’ profile?
wilkinson_raw_ads.dxf (166.4 KB)
wilkinson.dxf (87.6 KB)
The second file was cleaned up a bit in AutoCAD 2022.
Hi @mbe9a
I’ve started from the cleaned file…
In FC I had to convert it to a sketch, because it seems the edges were not oriented on the same versus… then I could apply the process to create a poly pad footprint…
(I know I would need to build some doc)
here the FC file and kicad footprint
wilk-fp.FCStd (63.4 KB)
wilk-fp.kicad_mod (8.1 KB)
Testing something here. @moderators
Sadly, no. System recognizes this group but doesn’t seem to alert. :frowning:
@ChrisGammell Anything in the back end that might fix this?
Amazing! Thanks! I have a bunch of designs to do, could you share the steps you took to do this when you get a chance?
That group exists but only people in the group can message it so that we’re not being summoned like genies :smiley:
mbe9a did the right thing and stuck around on the forum for about 20 minutes to move up from a level zero user to a level 1 user.
This post explains more: Understanding Discourse Trust Levels
The good parts:
[A user can] get to trust level 1 by…
  • Entering at least 5 topics
  • Reading at least 30 posts
  • Spend a total of 10 minutes reading posts
Unfortunately I have little documentation written, apart the one at the forum…
https://forum.kicad.info/search?q=StepUp RF
I asked few times to have some user in helping me to write some doc, but at the end when their job was done, the interest went away…
I haven’t any RF generator software, so it is quite difficult for me to imagine a path to be written in a doc
Maybe this post will help:
or here with another part of the StepUp tool (just keep reading :wink: ):
