I currently have KiCad 7.0.10 installed on my computer (using Windows 10). I’d like to add a QR as silkscreen to my PCB. I can go through the process of having one created online, then convert the image file to a kicad_mod file, then insert into the PCB. But I’d like to learn how to use plugins/scripts.
In this file path, I have a slew of Python scripts, including kicad_qrcode.py:
C:\Program Files\KiCad\7.0\share\kicad\scripting\plugins
When in PCB Editor, if I click Tools, External Plugins, Open Plugin Directory, the following directory is opened:
C:\Users\matts\Documents\kicad\7.0\scripting\plugins
That difference in file path is in of itself a little confusing. Any explanation on the different paths would be helpful. In any case, I’d like to understand and use the kicad_qrcode.py file. I found it posted online on GitHub here: kicad-footprint-wizards/kicad_qrcode.py at master · KiCad/kicad-footprint-wizards · GitHub
Is this a file I can use to generate a QR code natively within KiCad?? If so, how do I do this? If not, is there some other way to accomplish this entirely within KiCad, without doing the import image and convert to kicad_mod method listed above? I am not finding much helpful information online on this.
Thanks so much!!
