i use GerberPanelizer for make panel
but i try export gerber file can’t open in GerberPanelizer
this file
and zip file open in GerberPanelizer
not display Edge cut ?
how to export format support ?
i use Kicad 8.0.7
this file
i use Kicad 8.0.7
I assume by GerberPanelizer you mean this suite of tools:
Unfortunately you have to ask the author of that project, as this is not part of KiCad. I see that you have put in an issue for KiCad 7 so the problems are not new. It doesn’t look like the author has done work on the software for the last 3 years.
Maybe look for a different panelizer tool.
A long time ago, I think it was with KiCad 5.1 I got it to work on one of my boards, but it was finicky and only one particular release would work with Mono on Linux. I’m very unimpressed with C#. It’s worse than Java.
Try kikit panalization or the simplified version from SparkFun
all this is available from the plugins section
yes i not sure how to export is work
i try but not have document or video tutorial for kicad 8.0
