I completed a search on this forum and general Google - but no answer to the issue which resolves - when selecting help files they are not available.
Help file ‘kicad’ could not be found.
I downloaded the pdf documents and placed them in /usr/share/kicad.
I then added to Preferences -> Configure Paths selection - added KICAD name and the path to the pdf documents - and still not working.
Is this a bug or is my NAME (KICAD) incorrect etc.?
Any help gratefully received.
I am using Fedora 25 64bit.
Thanks and Regards,
Shadders.
pedro
March 17, 2017, 1:47pm
2
Don’t know Fedora. In Kubuntu
file:///usr/share/doc/kicad/help/en/kicad.html#_kicad
No need of Configure paths, that is only for environment variables I think.
Hi Pedro,
Thanks for the reply. I am not sure what you are inferring.
Is the path you have provided to be added somewhere ?.
I am using KDE - so should be similar to Kubuntu.
Thanks and regards,
Shadders.
HI Pedro,
I do feel a bit of dipstick - i looked at the documentation directory and saw the INSTALL.txt document and documentation is optional - the documentation directory was empty.
So i have just downloaded and installed (dnf install kicad-docs) and all is working ok.
Thanks and regards,
Shadders.
