Heads up: no-connect pins still get connected
Just a quick warning about the “No-connect” attribute on pins. KiCad ignores all the attributes when generating a netlist, so even if you have a pin set to no-connect, it can still get connected to a net.
I accidentally had a net connected to a no-connect pin, it had me baffled for quite a while!
I had assumed No-connect would mean it never gets connected, but basically it’s just information for the user.
To catch this type of error, never use Hidden pins and ALWAYS run ERC, even after the smallest of changes. Both you and ERC check have to be on your toes to avoid getting an invalid netlist.
One major correction: It’s just information for the ERC. Basically.
And in such situation(s) the ERC do his job as expected.
BTW: I found a worse issue that the ERC can not even detect! Bug #1522583 “Using tilde inside labels may confuse ERC module i...” : Bugs : KiCad
Huh, that one fell off my radar. I might poke at it again.
