Dear all,
Could you please tell me where I can download the footprint of this connector? Or is there a generic one?
Dear all,
If the footprint @RaptorUK shows is not suitable; it would be best for you to click on the below icon and look for yourself.
be careful, HDF-R44-213L011 is a female connector
You have selected a generic symbol for a 15 pin connector. That symbol is an abstract description of any physical fifteen pin connector.
To find a footprint you first have to decide the gap between the pins and the shape of the connector and whether it is to be THT or SMD; then you have to search through the libraries to find a footprint with 15 pins spaced as you want with or without a mounting system for mechanical strength.
You’re looking at symbols, not footprints. You can use any generic connector symbol with the right pin count (and the right mounting pin/shield type) and assign the footprint manually.
Indeed, the OP has final responsibility for the footprint they select, I was just trying to get them on the right tracks . . . this looks more correct but the PCB edge is not shown/is incorrect . . .
I found the right one, thanks!
Same question for SAMTEC ERF8-050-07.0-L-DV-TR
Is this the correct footprint? I don’t think so because some pins are not assigned.
You can get symbols, footprints and 3D CAD from Samtec
done, thanks I finished it
