Please refer to the image, I have three impedance tracks on pin 3,9 and 14
Please refer to recommended footprint dimensions.
Attached is the footprint
QFN16_rfaxis1010.kicad_mod (2.4 KB)
I only have two net classes
Default with 0.21mm clearance and 0.21mm width
For RF track 0.366mm width and 0.25mm clearance.
Can you let me know what is incorrect with the foot print or if the error is else where can you please point out.
** Found 5 DRC errors **
ErrType(19): Pad near pad
@ (145.600 mm,98.250 mm): Pad 3 on F.Cu, Non-copper of U2
@ (147.000 mm,98.000 mm): Pad 17 on F.Cu, Non-copper of U2
@ (145.600 mm,98.750 mm): Pad 4 on F.Cu, Non-copper of U2
@ (146.250 mm,99.400 mm): Pad 5 on F.Cu, Non-copper of U2
@ (147.250 mm,96.600 mm): Pad 14 on F.Cu, Non-copper of U2
@ (147.750 mm,96.600 mm): Pad 13 on F.Cu, Non-copper of U2
@ (148.400 mm,97.250 mm): Pad 12 on F.Cu, Non-copper of U2
@ (147.750 mm,99.400 mm): Pad 8 on F.Cu, Non-copper of U2
@ (148.400 mm,98.750 mm): Pad 9 on F.Cu, Non-copper of U2
** Found 0 unconnected pads **
** End of Report **
Can I create multiple clearance for the same net in case of RF tracks, if that is causing the DRC violations?
