Have I missed something? (schematic copy/paste)
OK just downloaded the latest build. 5.1.xxx
Opened an old Kicad schematic. select-cut the part I wanted.
Opened a new instance of Kicad, made a new project, new schematic…
It seems that:
  1. i am stupid. (not a stretch)
    –or–
  2. I still cannot cut and paste from schematic to schematic.
    Someone PLEASE prove that by version 5.1.xxxxx
    #1 is true, and not #2
Thanks,
—Lou
I fear that you are a smart person. :expressionless: I think that what you say is consistent with what I have heard. I would test it but I am running 5.99.
Unfortunately that is a new feature coming with V6 (present currently on the nightly builds aka. v5.99 used for testing). for the current stable release it is not possible to copy/paste between different instances.
When I copy and paste, I work WITHIN the SAME instance of eeschema to do the copy / paste.
Open source diagram, copy, open other diagram in the SAME instance, then paste.
NEVER had any problem moving / duplicating items between schematics.
If I remember correctly the workaround is:
  • The new project into which you want to paste is active
  • Create a hierarchical sheet and go into it
  • File -> Append Schematic
  • Copy from there
  • Go to the upper level and paste
  • When you’re done, delete the temporary hierarchical sheet.
The workaround above by Meterman seems to work only if eeschema is in standalone mode, i.e. not opened through a project. It also works only if the libraries are common to the two schematics (projects).
Kicad (eeschema) has been started sometime in early 90’s. That history comes with a baggage, and this is part of it. In version 5.99 most of the history has been cleaned and eeschema behaves as a decent modern application.
eelik: You are correct that eeschema has to be run in standalone mode to be able to do this. It was a good and easy way to ensure I got all the inter-board connectors in my project just right.
Once I was ready to start translating the schematics into actual PC board layouts, THEN I switched from standalone mode to individual projects.
