Have any user of Kicad already created a symbol for TA7358
A search gets a gEDA symbol but AFAIK there is no converter from gEDA .sym format to KiCad .kicad_sym format, only from. Seems there was some discussion about a converter but I can’t find any follow up.
It’s only a 9-pin SIP IC, so should be quite fast to create your own. The circuit on this page might help you set the pin types, probably Power Input for GND and VCC and Passive for the others will work.
Good luck, and submit your symbol if you want your work to help others, though there probably isn’t much demand for this chip now.
