Has 6.0.7 vanished?
Just tried to download the Windows version and all the links are saying file not found?
The release was just announced, I’d wait a bit. KiCad releases are usually not very well synchronized, the source is released and the packages take a little time to trickle down. Someone might have updated the website a little prematurely.
Use the GitHub or CERN links. They are guaranteed to be available on release day.
All other links are mirrors that may take 24 hours
Unfortunately the GitHub and CERN links doesn’t work for the Windows version. :frowning:
The correct Github link is:
https://github.com/KiCad/kicad-source-mirror/releases/download/6.0.7/kicad-6.0.7-x86_64.exe
On the download page the name of the exe has gotten a “_1” after the version number for some reason."
https://github.com/KiCad/kicad-source-mirror/releases/download/6.0.7/kicad-6.0.7_1-x86_64.exe
This is what the CERN link does (Win11):
Same thing with the CERN link. This link works:
https://kicad-downloads.s3.cern.ch/windows/stable/kicad-6.0.7-x86_64.exe
The one on the download page says:
https://kicad-downloads.s3.cern.ch/windows/stable/kicad-6.0.7_1-x86_64.exe
That would imply that there was a rebuild and the “_1” is the correct but not distributed version
Interesting. :smiley:
At least it seems to work fine. I’ll keep my eyes open for announcements though.
Application: KiCad PCB Editor (64-bit)
Version: (6.0.7), release build
wxWidgets 3.1.7
libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 11 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jul 26 2022 02:49:38
wxWidgets: 3.1.7 (wchar_t,wx containers)
Boost: 1.79.0
OCC: 7.6.0
Curl: 7.83.1-DEV
ngspice: 37
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Seems broken here
The post from @albin is that the version on the server without the “_1” seems to work
I am not sure why the download page his pointing to a non-existent “_1”
Yes I have done the download from the other link.
Whatever it was, It’s fixed.
[Edit] Obviously not by me :wink:
And now there is no “_1”
I will distribute this 6.0.7 at work
Sorry about that folks! 6.0.6 had a _1 appended because it had a packaging revision and in the course updating the website, we neglected to remove the _1
Should be all good now
No sweat, sh*t happens :slightly_smiling_face:
Download and install went fine this afternoon (MDT). Good to go from github.
6.0.7 downloads work fine now.
Users of this version should be aware that STEP export is broken. If you need this, download a “Testing Lite” version and update
How is Step export broken? I have done several step files, and they seem to work. I have Win10/64 and 6.0.7.
I am searching for it, there was also an issue with DRC error count that got through
