Half side vias?
how are these called, and is it possible in Kicad ?
thanks for your help
just a 2 sided pcb
  • so if I put a via on a edge cut, JLCPCB will know how to process that?
  • these are square pads and it is not just cut off the board, the sides seems to be copper filled
there maybe is an alternative, I dont have much space for connection on the pcb itself, and the solder/wires also must be flush
hence my interest in the subject
I misunderstood… I assumed by the wording “half side…” you meant one-side of a two sided PCB.
Yes, castellated is what you want…
Examples on Edge using different THT’s and Via… This is an old screenshot that doesn’t have half-depth vias… as I showed in first photo(now deleted)…
With some Rectangular/Square THT Pads
thanks guys, I guess the words comes from castle or something :slight_smile:
found this about JLCPCB process
Castellated PCBs: Introduction and Design Requirements - JLCPCB
