Grouping parts in PCB Editor
I have a complex CPU BGA part where I have placed all the bypass capacitors close to the appropriate pins going to the backside of the PCB. Is there a way to essentially associate the MCU footprint with all the bypass capacitors and inductors in a way that if I select the MCU, all the associated caps are also selected and moved together should I decide to move my layout around. I realize I can drag and select all them at once but just curious if there is a way to create that association such that it acts as a single layout?
Yes, you can group them in the PCB layout . . . select what you want in the group, right click and . .
(from V7.0.6)
