When I fill the zones on my two layer PCB it doesn’t cover the GND pins of the components. I did click GND when setting the zones. Can someone help me?
screenshot, maybe pcb file would help a lot…
In the zone’s properties make sure the net name is the same as your GND net name. Also make sure ‘Pad Connection’ is not ‘None’, you probably want ‘Thermal Relief’.
Check your clearance and minimum width settings.
Zones have their own settings.
