Hello!
I noticed that when routing a board, grid switches automatically without asking me and even
without telling me it has switched. The result is that when starting (for instance) at 0.25mm,
then sometimes it switches automatically to 0.20 and the circuit becomes a real mess, all
the subsequent moves will end on the 0.20 mm (or other) grid. Resistors end up unaligned, etc.
Is there a way to completely disable this behavior? I mean, for good, not only on the current board?
Sorry, as this behaviour is not new (I experienced it a few times in the past),
I didn’t think the version was important.
But you’re right, I should always include the version, just in case.
Are you perhaps accidentally hitting “N” on your keyboard? That is a shortcut for switching grids with very little obvious notice and it has confused me in the past. You can remove or change it in hotkey preferences at the user level.
Also: if you are routing in shove or walkaround mode; the router does not restrict tracks to being on the grid. This is by design. You can push tracks as close together as your clearance rules allow.
Do you mean that in shove mode, it could alter my current setting (the value in the popup menu
at the top of PCB layout window? That would be weird. Is there a way to disable this behaviour?
Thanks for your reply.
Ok then it’s not a problem. Shove mode means “active” routing, I see what I do. The only problem
was that if the grid switches, I may not notice and then end up with everything screwed up.
