Grid dots in general
Greetings,
this may be a shot in the dark, but here is my comment/question.
regarding grid dots, when dots are enabled, “every 10th” dot is a small line. i know this is by design and most major cad packages have this it drives me nuts. I’m used to the older OrCAD packages which has ALL grid dots, and if i recall, you can adjust the major/minor dot. is there a way to switch EVERYTHING to grid dots and not have the every 10th dot as a line ? perhaps somewhere in one of the json or xml files ?
please advise
If you set the grid display option in the schematic editor options or the pcb editor option to “Dots”, nothing will be a line? Just every 10th dot is a slightly bigger/darker dot.
Preferences->(Schematic/PCB/Footprint) Editor->DisplayOptions
When zoomed in they look like squares and vertical lines . . .
Horizontal lines for the y and vertical for the x, squares at the intersect. Most noticeable at zoom = 1, 13 & 20
thanks to whom ever replied, but didn’t answer my question.
No. There is no way.
