Good morning all,
The great thing about Kicad is that all of its files end up in text format and are mostly readable.
I have recurring need to generate regular and odd shaped arrays of LEDs on circuit boards. Consider a polar array of 4 rings of 40 LEDs. That is 160 LEDs, each with a specific location, rotation, and 6 pads to connect via traces to other LEDs. Turns out it is about 4000 mouse movements and/or keystrokes.
SO! After doing one or two of these I decided that the whole process needs to be automated. I have a tiny bit of ability in python, and maybe intermediate experience with grasshopper/rhino 6.
Thus far I have a grasshopper patch that totally works for making a layout in kicad PCBNEW, with nets and traces. AMAZING. However, it only works with a specific LED part. This is OK for me as I almost only use this type of LED in my work and if I have to change it for a different one, the amount of work to do so is FAR LESS than manually building LED arrays in Kicad.
However, working with only a PCB layout seems a bit risky, and what if later I want a very similar board with just a few easy tweaks. I need an associated schematic.
The short goal is to finish my grasshopper patch such that it generates both a schematic AND a PCB layout file for Kicad. This I can do with what I know. (And I do have a very clunky version working)
But ultimately I would love to generalize this system such that any Kicad component (both sch symbol AND pcb footprint) can be imported into grasshopper and arrayed based on generative and parametric geometry created within.
Back to the idea that Kicad stores everything as text files:
The symbol libraries and pcb footprints are text files in the S-Expression format and tokens are divided up with parentheses ( ) and whitespace âspacesâ).
Kicad docs file formats
I will most likely be writing some python in GH to help with this, but right now I am stuck on how to parse the Kicad schematic Library files into Grasshopper on a part by part basis (as the symbols are all part of 1 larger library file). I suppose I could create single-part libraries, and this would certainly simplify things. But againâŚI am trying to generalize this system for the benefit of whomever else might want to use it.
Here is a truncated example of a kicad6 schematic symbol library
(kicad_symbol_lib (version 20211014) (generator kicad_symbol_editor)
(symbol ".1-PAD" (pin_names (offset 1.016)) (in_bom yes) (on_board yes)
(property "Reference" "P" (id 0) (at 0 0 0)
(effects (font (size 1.27 1.27)))
(property "Value" ".1-PAD" (id 1) (at 0 0 0)
(property "Footprint" "" (id 2) (at 0 0 0)
(effects (font (size 1.27 1.27)) hide)
(property "Datasheet" "" (id 3) (at 0 0 0)
(symbol ".1-PAD_1_1"
(pin input line (at 0 -1.27 0) (length 2.54)
(name "~" (effects (font (size 1.27 1.27))))
(number "~" (effects (font (size 1.27 1.27))))
(symbol "10-BITD-TYPELATCH" (pin_names (offset 1.016)) (in_bom yes) (on_board yes)
(property "Reference" "U" (id 0) (at 0 -34.29 0)
(property "Value" "10-BITD-TYPELATCH" (id 1) (at 0 0 0)
(symbol "10-BITD-TYPELATCH_0_1"
(rectangle (start -7.62 -2.54) (end 6.35 -33.02)
(stroke (width 0) (type default) (color 0 0 0 0))
(fill (type none))
(symbol "10-BITD-TYPELATCH_1_1"
(pin input line (at -12.7 -3.81 0) (length 5.08)
(name "OE_BAR" (effects (font (size 1.27 1.27))))
(number "1" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -26.67 0) (length 5.08)
(name "9D" (effects (font (size 1.27 1.27))))
(number "10" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -29.21 0) (length 5.08)
(name "10D" (effects (font (size 1.27 1.27))))
(number "11" (effects (font (size 1.27 1.27))))
(pin power_in line (at -12.7 -31.75 0) (length 5.08)
(name "GND" (effects (font (size 1.27 1.27))))
(number "12" (effects (font (size 1.27 1.27))))
(pin power_in line (at 11.43 -31.75 180) (length 5.08)
(name "LE" (effects (font (size 1.27 1.27))))
(number "13" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -29.21 180) (length 5.08)
(name "10Q" (effects (font (size 1.27 1.27))))
(number "14" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -26.67 180) (length 5.08)
(name "9Q" (effects (font (size 1.27 1.27))))
(number "15" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -24.13 180) (length 5.08)
(name "8Q" (effects (font (size 1.27 1.27))))
(number "16" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -21.59 180) (length 5.08)
(name "7Q" (effects (font (size 1.27 1.27))))
(number "17" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -19.05 180) (length 5.08)
(name "6Q" (effects (font (size 1.27 1.27))))
(number "18" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -16.51 180) (length 5.08)
(name "5Q" (effects (font (size 1.27 1.27))))
(number "19" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -6.35 0) (length 5.08)
(name "1D" (effects (font (size 1.27 1.27))))
(number "2" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -13.97 180) (length 5.08)
(name "4Q" (effects (font (size 1.27 1.27))))
(number "20" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -11.43 180) (length 5.08)
(name "3Q" (effects (font (size 1.27 1.27))))
(number "21" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -8.89 180) (length 5.08)
(name "2Q" (effects (font (size 1.27 1.27))))
(number "22" (effects (font (size 1.27 1.27))))
(pin output line (at 11.43 -6.35 180) (length 5.08)
(name "1Q" (effects (font (size 1.27 1.27))))
(number "23" (effects (font (size 1.27 1.27))))
(pin power_in line (at 11.43 -3.81 180) (length 5.08)
(name "VCC" (effects (font (size 1.27 1.27))))
(number "24" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -8.89 0) (length 5.08)
(name "2D" (effects (font (size 1.27 1.27))))
(number "3" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -11.43 0) (length 5.08)
(name "3D" (effects (font (size 1.27 1.27))))
(number "4" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -13.97 0) (length 5.08)
(name "4D" (effects (font (size 1.27 1.27))))
(number "5" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -16.51 0) (length 5.08)
(name "5D" (effects (font (size 1.27 1.27))))
(number "6" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -19.05 0) (length 5.08)
(name "6D" (effects (font (size 1.27 1.27))))
(number "7" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -21.59 0) (length 5.08)
(name "7D" (effects (font (size 1.27 1.27))))
(number "8" (effects (font (size 1.27 1.27))))
(pin input line (at -12.7 -24.13 0) (length 5.08)
(name "8D" (effects (font (size 1.27 1.27))))
(number "9" (effects (font (size 1.27 1.27))))
(symbol "39-30-3047" (pin_names (offset 0.762)) (in_bom yes) (on_board yes)
(property "Reference" "J" (id 0) (at 16.51 7.62 0)
(effects (font (size 1.27 1.27)) (justify left))
(property "Value" "39-30-3047" (id 1) (at 16.51 5.08 0)
(property "Footprint" "39303047" (id 2) (at 16.51 2.54 0)
(effects (font (size 1.27 1.27)) (justify left) hide)
(property "Datasheet" "http://de.rs-online.com/web/p/leiterplatten-header/6705868" (id 3) (at 16.51 0 0)
(property "Description" "Molex MINI-FIT JR. Series, Series Number 5569, 4.2mm Pitch 4 Way 1 Row Right Angle PCB Header, Solder Termination, 12A" (id 4) (at 16.51 -2.54 0)
(property "Height" "6.18" (id 5) (at 16.51 -5.08 0)
(property "Manufacturer_Name" "Molex" (id 6) (at 16.51 -7.62 0)
(property "Manufacturer_Part_Number" "39-30-3047" (id 7) (at 16.51 -10.16 0)
(property "Mouser Part Number" "538-39-30-3047" (id 8) (at 16.51 -12.7 0)
(property "Mouser Price/Stock" "https://www.mouser.co.uk/ProductDetail/Molex/39-30-3047/?qs=404muyNbhLFMA7DI2g4beQ%3D%3D" (id 9) (at 16.51 -15.24 0)
(property "ki_description" "Molex MINI-FIT JR. Series, Series Number 5569, 4.2mm Pitch 4 Way 1 Row Right Angle PCB Header, Solder Termination, 12A" (id 10) (at 0 0 0)
(symbol "39-30-3047_0_0"
(pin passive line (at 0 -7.62 0) (length 5.08)
(name "1" (effects (font (size 1.27 1.27))))
(pin passive line (at 0 -5.08 0) (length 5.08)
(name "2" (effects (font (size 1.27 1.27))))
(pin passive line (at 0 -2.54 0) (length 5.08)
(name "3" (effects (font (size 1.27 1.27))))
(pin passive line (at 0 0 0) (length 5.08)
(name "4" (effects (font (size 1.27 1.27))))
(symbol "39-30-3047_0_1"
(polyline
(pts
(xy 5.08 2.54)
(xy 15.24 2.54)
(xy 15.24 -10.16)
(xy 5.08 -10.16)
(xy 5.08 2.54)
(stroke (width 0.1524) (type default) (color 0 0 0 0))
(fill (type none))
(symbol "43650-0303" (pin_names (offset 0.762)) (in_bom yes) (on_board yes)
(property "Value" "43650-0303" (id 1) (at 16.51 5.08 0)
(property "Footprint" "43650-03-03040559" (id 2) (at 16.51 2.54 0)
(property "Datasheet" "https://www.molex.com/pdm_docs/sd/436500203_sd.pdf" (id 3) (at 16.51 0 0)
(property "Description" "Micro-Fit 3.0 Right-Angle Header, 3.00mm Pitch, Single Row, 3 Circuits, with PCB Press-fit Metal Retention Clip, Glow-Wire Capable, Black" (id 4) (at 16.51 -2.54 0)
(property "Height" "5.57" (id 5) (at 16.51 -5.08 0)
(property "Manufacturer_Part_Number" "43650-0303" (id 7) (at 16.51 -10.16 0)
(property "Mouser Part Number" "538-43650-0303" (id 8) (at 16.51 -12.7 0)
(property "Mouser Price/Stock" "https://www.mouser.co.uk/ProductDetail/Molex/43650-0303/?qs=P7cO%252B%252BFDLzRIPB7V1gsyvg%3D%3D" (id 9) (at 16.51 -15.24 0)
(property "ki_description" "Micro-Fit 3.0 Right-Angle Header, 3.00mm Pitch, Single Row, 3 Circuits, with PCB Press-fit Metal Retention Clip, Glow-Wire Capable, Black" (id 10) (at 0 0 0)
(symbol "43650-0303_0_0"
(pin passive line (at 20.32 -5.08 180) (length 5.08)
(pin passive line (at 20.32 -2.54 180) (length 5.08)
(pin passive line (at 20.32 0 180) (length 5.08)
(name "5" (effects (font (size 1.27 1.27))))
(symbol "43650-0303_0_1"
(polyline
(pts
(xy 5.08 2.54)
(xy 15.24 2.54)
(xy 15.24 -7.62)
(xy 5.08 -7.62)
(xy 5.08 2.54)
(fill (type none))
(symbol "43650-0320" (pin_names (offset 0.762)) (in_bom yes) (on_board yes)
(property "Value" "43650-0320" (id 1) (at 16.51 5.08 0)
(property "Footprint" "436500320" (id 2) (at 16.51 2.54 0)
(property "Datasheet" "https://www.molex.com/pdm_docs/sd/436500320_sd.pdf" (id 3) (at 16.51 0 0)
(property "Description" "MOLEX - 43650-0320 - WTB CONNECTOR, HEADER, 3POS, 1ROW, 3MM" (id 4) (at 16.51 -2.54 0)
(property "Height" "9.9" (id 5) (at 16.51 -5.08 0)
(property "Manufacturer_Part_Number" "43650-0320" (id 7) (at 16.51 -10.16 0)
(property "Mouser Part Number" "538-43650-0320" (id 8) (at 16.51 -12.7 0)
(property "Mouser Price/Stock" "https://www.mouser.co.uk/ProductDetail/Molex/43650-0320?qs=ELX02gy%2F6bhyW2r1pYZDww%3D%3D" (id 9) (at 16.51 -15.24 0)
(property "ki_description" "MOLEX - 43650-0320 - WTB CONNECTOR, HEADER, 3POS, 1ROW, 3MM" (id 10) (at 0 0 0)
(symbol "43650-0320_0_0"
(symbol "43650-0320_0_1"
(polyline
(pts
(xy 5.08 2.54)
(xy 15.24 2.54)
(xy 15.24 -7.62)
(xy 5.08 -7.62)
(xy 5.08 2.54)
(fill (type none))
(symbol "632-tight-fit" (pin_names (offset 1.016) hide) (in_bom yes) (on_board yes)
(property "Reference" "J" (id 0) (at 0 2.54 0)
(property "Value" "632-tight-fit" (id 1) (at 0 -2.54 0)
(property "Datasheet" "~" (id 3) (at 0 0 0)
(property "ki_keywords" "connector" (id 4) (at 0 0 0)
(property "ki_description" "Generic connector, single row, 01x01, script generated (kicad-library-utils/schlib/autogen/connector/)" (id 5) (at 0 0 0)
(property "ki_fp_filters" "Connector*:*_1x??_*" (id 6) (at 0 0 0)
(symbol "632-tight-fit_1_1"
(rectangle (start -1.27 0.127) (end 0 -0.127)
(fill (type none))
(rectangle (start -1.27 1.27) (end 1.27 -1.27)
(stroke (width 0.254) (type default) (color 0 0 0 0))
(fill (type background))
(pin passive line (at -5.08 0 0) (length 3.81)
(name "Pin_1" (effects (font (size 1.27 1.27))))
(symbol "APA102" (in_bom yes) (on_board yes)
(property "Reference" "D" (id 0) (at 5.08 5.715 0)
(effects (font (size 1.27 1.27)) (justify right bottom))
(property "Value" "APA102" (id 1) (at 1.27 -5.715 0)
(effects (font (size 1.27 1.27)) (justify left top))
(property "Footprint" "LED_SMD:LED_RGB_5050-6" (id 2) (at 1.27 -7.62 0)
(effects (font (size 1.27 1.27)) (justify left top) hide)
(property "Datasheet" "http://www.led-color.com/upload/201506/APA102%20LED.pdf" (id 3) (at 2.54 -9.525 0)
(property "ki_keywords" "RGB LED addressable 8bit pwm 5bit greyscale" (id 4) (at 0 0 0)
(property "ki_description" "RGB LED with integrated controller" (id 5) (at 0 0 0)
(property "ki_fp_filters" "LED*RGB*5050*" (id 6) (at 0 0 0)
(symbol "APA102_0_0"
(text "RGB" (at 2.286 -4.191 0)
(effects (font (size 0.762 0.762)))
(symbol "APA102_0_1"
(polyline
(pts
(xy 1.27 -3.556)
(xy 1.778 -3.556)
(fill (type none))
(polyline
(pts
(xy 1.27 -2.54)
(xy 1.778 -2.54)
(fill (type none))
(polyline
(pts
(xy 4.699 -3.556)
(xy 2.667 -3.556)
(fill (type none))
(polyline
(pts
(xy 2.286 -2.54)
(xy 1.27 -3.556)
(xy 1.27 -3.048)
(fill (type none))
(polyline
(pts
(xy 2.286 -1.524)
(xy 1.27 -2.54)
(xy 1.27 -2.032)
(fill (type none))
(polyline
(pts
(xy 3.683 -1.016)
(xy 3.683 -3.556)
(xy 3.683 -4.064)
(fill (type none))
(polyline
(pts
(xy 4.699 -1.524)
(xy 2.667 -1.524)
(xy 3.683 -3.556)
(xy 4.699 -1.524)
(fill (type none))
(rectangle (start 5.08 5.08) (end -5.08 -5.08)
(symbol "APA102_1_1"
(pin input line (at -7.62 2.54 0) (length 2.54)
(name "DI" (effects (font (size 1.27 1.27))))
(pin input line (at -7.62 0 0) (length 2.54)
(name "CI" (effects (font (size 1.27 1.27))))
(pin power_in line (at 0 -7.62 90) (length 2.54)
(pin power_in line (at 0 7.62 270) (length 2.54)
(pin output line (at 7.62 0 180) (length 2.54)
(name "CO" (effects (font (size 1.27 1.27))))
(pin output line (at 7.62 2.54 180) (length 2.54)
(name "DO" (effects (font (size 1.27 1.27))))
I can load this into GH with a file read component and view it in a panel, but I am at a loss as to how to parse out each symbol from the larger file (this file will change over time, so index or line specific parsing is not optional)(How do I parse indentations/whitespace?)
I would like to separate each âsymbolâ from the larger list, prepare each symbol for text formatting, and extract numerical info from the âsymbolâ to use in the creation of geometry for visualization and for wire/trace routing.
Once I figure out how to separate the âsymbolsâ, then getting the other bits of info out of each text fragment should be trivial.
Any advice on how to parse this kind of file?
Thanks
