I previously imported filled shapes from Inkscape via the import graphics function and set the imported shape to be a filled shape with a line thickness of 0. However, that’s not working any more. Am I doing something wrong or is this a regression?
ok, the shape was not closed, maybe that was an issue. However it still doesn’t work as expected and I am sure that it used to work fine, maybe 6 months ago.
I need to set it a filled shape, but can’t, as KiCad only lets me select line segments. Am I doing something terribly wrong?
I have not changed the - and + signs since the last import, but even those I can’t import properly any more. Were there any changes relating to the SVG import in Nightly?
