I’m using the modern toolset.
When using pcbnew / add graphic lines, it gives the impression that all lines are attached each other and you seem to draw a polyline. Which is wrong, because if you move a line extremity after a selection, one line only is moving.
Is there a way to draw a polyline (not a polygon) in pcbnew, and close it easily ?
