Is there a way to grab a component in EEschema and to have the wires follow with right angles and not only the shortest route ?
Thanks,
Thanks,
You have to strategically ‘select’ the wires as well (as a block) and then use [TAB], before moving things into one direction (vertical/horizontal) - the only answer I have for you…
