Got error when using fabrication tool kit with Nightly
Got following error when running fabrication tool kit with Nightly. Suspect it’s a bug with the Design block function. Any help fixing the issue is much appreciated.
FOOTPRINT.Duplicate() missing 1 required positional argument: 'addToParentGroup’
Version: 9.99.0-3665-g677676f457, release build
wxWidgets 3.3
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
Platform: Windows 11 (build 26200), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: ATI Technologies Inc., AMD Radeon™ 890M Graphics, 4.6.0 Compatibility Profile Context 25.9.1.250822
Date: Oct 14 2025 07:38:35
wxWidgets: 3.3.0 (wchar_t,STL containers)
Boost: 1.88.0
OCC: 7.9.1
Curl: 8.13.0-DEV
ngspice: 45.2
KICAD_IPC_API=ON
KICAD_USE_PCH=OFF
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
You’re using 9.99. Bugs are expected. 9.99 probably won’t be stable for another 3 months.
It is best for you to report this as a bug in Gitlab.
If you create a very simple repro step and share the project file, maybe someone will take a look.
