I have a PCB board designed with one edge having a double sided gold fingered edge connector. To have the gold plated during manufacture, I must connect all the edge connector fingers with 0.008 inch trace. I was wanting to have this connector trace be on the outside of the board edge so that it will be cut off after plating.
Two Issues:
- I can’t seem to draw a trace across the board edge. I have removed the edge and I will add it back after the traces for all the fingers are drawn. Is there an easier way to do this?
- KiCad doesn’t appear to let me connect pads together that are not connected in the design netlist. Is there any way to change a setting such that I an connect these pads?
Thanks!
