Hi.
Is it possible to change components properties globally?
I have the need to change a large number of resistor to different package.
I have selected all incorrect resistors and right-clicked to get properties, but menu does not appear.
Regards
In principle yes, with different ways.
But we need more info:
Used kicad version?
Used editor? (board or schematic? The word âcomponentsâ doesnât helps - schematics contain symbols and the board contains footprints).
Hi.
thank you for your reply.
I did post under âshematicâ.
Yes you are right i should have said âsymbolâ.
I am using KiCad 7.
Regards
Changing the footprint for multiple symbols (in the schematic editor):
- use the command Toolsâ>Assign footprints (also available as button on top toolbar).
- use the Toolsâ>Edit symbol fields table (also available as button on top toolbar). Here you have to first change the footprint-field of the first symbol, than you can copy/paste this footprint-string to the other footprint-fields (like a spreadsheet calculator)
Sadly both tools show the complete list of symbols and not a reduced list of previously selected symbols, so for very large schematics these dialogs are pretty large.
The symbol fields table at least allows to filter with a search-string.
Thank you very much for your help, it works.
Regards.
