Global library does not show up (solved)
I’m trying to create a global library to add my foot print to. I created the library and using the wizard added the library(it’s called Igor in the first image).
When i try to select a library, this library does not show up (second image).
Instead i created a test library and added to only this project and it shows up just fine.
How do i make a global library?
Have you tried restarting kicad?
(Someone else had a similar problem that was fixed by simply restarting kicad.)
If this does not work:
What is your kicad version?
Which operating system?
Restarting KiCad did the trick.
