suddenly a ghost button appeared out of nowhere while I was editing another footprint
as I click on the 3D view, sadly it does not show in the 2D view, which component it is related to
how can I fix this ? its just cosmetic but it’s annoying
There could be more than one 3D entries at different positions in the footprint definition.
the problem is to find which one
is there no 3D view → 2D view selection ?
You may need to check some footprint definitions one by one.
Or just temporarily move the suspects around and see what moves with it.
the problem is to find which one. is there no 3D view → 2D view selection?
No.
But there is a 2D-3D-highlighting.
I checked the footprints list in schematic editor, the count of cherry mx switches is correct
I dont see where that ghost cap comes from
and here comes another one
I swear I did not change any footprint, I am just moving components around
Which component have you moved?
It seems you have copied the path of this button into another footorint 3d setting.
if willing to post your file, that would save users/viewers a good amount of back&forth posting while providing the actual problem source…
EDIT: Check the panel where you link the footprint, sometimes I mess up and forget to delete a duplicated one… (and, it may have a different/offset)
If you at last post your KiCad version information would be helpful.
It’s under
and paste it in here
Application: KiCad Schematic Editor (64-bit)
Version: (6.0.7), release build
wxWidgets 3.1.7
libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 10 (build 19044), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jul 26 2022 02:49:38
wxWidgets: 3.1.7 (wchar_t,wx containers)
Boost: 1.79.0
OCC: 7.6.0
Curl: 7.83.1-DEV
ngspice: 37
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
I created another kicad/python thread to ask how to find the component causing the issue here
apparently, updating components from the library creates an missing component and randomly assign 3D objects to some components
Update from library is a know point to consider.
That is one reason why it is always a good idea to have for every project its own library.
Anything customized goes in there. This avoids entanglements with stock libraries.
that’s what I did
I noticed some packages were missing from kicad too
while 3D objects I added are not even associated from the library AFAIK, it’s configured on PCB level
This is exactly what I meant.
