The foot prints from the main fp library didn’t have anything close to a connection part being used. So I downloaded digikey add-on library which actually sell the part used. I have the mfg #, the digikey # but again can’t find the right one to use. The connector is .1 lead pitch with 2 pins on one connection part and 10 pins on the other. The schematic symbol seems correct, but matching it to the footprint is way off.
Part one is pheonix contact #1729128 2pos wire to board coonector
digikey #277-1273-nd PCB shows as footprint 1/2 inch long by .4 inch wide and 3d view confirms as a 2 pos pin connector rather than a 2 terminal screw connector so I know I have the wrong footprint selected.
Same goes for the other part at 10 pins wide.
I there a 3d browse to footprint or something?
