Getting Connections
in my PCB layout How do i connect the Pins to the Connection to the edge-card, any help would be good
Screenshot at 2025-03-10 12-46-17
edge connector J2 PCB footprint should be associated to a J2 schematic symbol. Also J2 symbol pins should be connected to A1 module pins.
Have you done this?
Ive Made the Board i have not made the Edge Connector
the card edge connector: KYOCERA AVX # 009159010061916
Connected Device PCBs/OptaAuxBreakout at main · JeremySCook/PCBs · GitHub
Gerber Files: PCBs/OptaAuxBreakout at main · JeremySCook/PCBs · GitHub
card-edge
Designing the PCB board without schematic is not recommended. I suggest to follow these basic workflow guidelines: Getting Started in KiCad | 9.0 | English | Documentation | KiCad
You have two connectors referenced as J1. I believe KiCad (and any other PCB design program) will have a problem with it - how to distinguish their pads as they have the same name.
As you have connection lines between one J1 and A1 than probably you have them at schematic.
As you don’t have connection lines between them and second J1 and J2 than you should start from adding relevant connections at schematic.
thank you so much i will look into this .
