Is there a way to get tracks I drew to stick to the pins they connect to? S elms that even after I connect, if I move the part, the tracks stay out. I’m comparing this behavior to eagle which has sticky pins.
If this is intended, can you tell me why this is better? Eeschema seems to be like this too.
I don’t think your example is a particularly good one since you are moving the footprint to an unroutable spot. More realistic, is moving a couple mm, then just adjusting the tracks. I can see arguments for both ways. Would be interested in hearing some opinions. Both Eagle and Diptrace use sticky tracks. KiCAD doesn’t, and I believe Altium behaves like KiCAD.
