Some1 have a solution for this rosetta exception?
When KiCAD will run natively on M1?
Thanks,
Andrei
Translated Report (Full Report Below)
Process:               gerbview [3077]
Path:                  /Volumes/VOLUME/*/kicad.app/Contents/Applications/gerbview.app/Contents/MacOS/gerbview
Identifier:            org.kicad.gerbview
Version:               (5.1.12-1-10_14) ((5.1.12-1-10_14))
Code Type:             X86-64 (Translated)
Parent Process:        kicad [765]
Responsible:           kicad [765]
User ID:               501
Date/Time:             2022-07-01 10:25:26.3134 -0400
OS Version:            macOS 12.4 (21F79)
Report Version:        12
Anonymous UUID:        29CDC03B-7E75-05C3-FC39-AB55FCBE1917
Sleep/Wake UUID: 76614752-02C9-4B3F-993B-A8819782D9DB
Time Awake Since Boot: 35000 seconds
Time Since Wake:       1681 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [3077]
VM Region Info: 0 is not in any region.  Bytes before following region: 4303183872
REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
UNUSED SPACE AT START
__TEXT                      1007d6000-100841000    [  428K] r-x/rwx SM=COW  …acOS/gerbview
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   _gerbview.kiface              	       0x10f6e3de1 GERBVIEW_FRAME::OnUpdateSwitchCanvas(wxUpdateUIEvent&) + 97
1   _gerbview.kiface              	       0x10f6f905a GERBVIEW_FRAME::GERBVIEW_FRAME(KIWAY*, wxWindow*) + 4714
2   _gerbview.kiface              	       0x10f6c4ba0 GERBV::IFACE::CreateWindow(wxWindow*, int, KIWAY*, int) + 48
3   gerbview                      	       0x100809401 KIWAY::Player(FRAME_T, bool, wxTopLevelWindow*) + 433
4   gerbview                      	       0x1007db81e PGM_SINGLE_TOP::OnPgmInit() + 1102
5   gerbview                      	       0x1007dc66b APP_SINGLE_TOP::OnInit() + 123
6   libwx_osx_cocoau-3.0.0.4.0.dylib	       0x109ec542b wxApp::CallOnInit() + 155
7   libwx_osx_cocoau-3.0.0.4.0.dylib	       0x109e08d75 wxEntry(int&, wchar_t**) + 117
8   gerbview                      	       0x1007db340 main + 48
9   dyld                          	       0x2009a651e start + 462
Thread 1:: com.apple.rosetta.exceptionserver
0   runtime                       	    0x7ff7ffc2a9c4 0x7ff7ffc26000 + 18884
1   runtime                       	    0x7ff7ffc38460 0x7ff7ffc26000 + 74848
2   runtime                       	    0x7ff7ffc39ed8 0x7ff7ffc26000 + 81624
Thread 2:
0   runtime                       	    0x7ff7ffc48814 0x7ff7ffc26000 + 141332
Thread 3:
Thread 4:
Thread 5:
Thread 6:: com.apple.NSEventThread
0   ???                           	    0x7ff8abbc6940 ???
1   libsystem_kernel.dylib        	    0x7ff81b6109b6 semaphore_wait_trap + 10
2   libdispatch.dylib             	    0x7ff81b4967ce _dispatch_sema4_wait + 16
3   libdispatch.dylib             	    0x7ff81b496c9d _dispatch_semaphore_wait_slow + 98
4   HIToolbox                     	    0x7ff82483ae43 _BeginEventReceiptOnThread + 159
5   AppKit                        	    0x7ff81e1f4bbf _NSEventThread + 37
6   libsystem_pthread.dylib       	    0x7ff81b64d4e1 _pthread_start + 125
7   libsystem_pthread.dylib       	    0x7ff81b648f6b thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000  rbx: 0x0000000000000002  rcx: 0x00000000c1a0902e  rdx: 0x0000000000000000
rdi: 0x0000000000000000  rsi: 0x00000000000017e8  rbp: 0x000000030522d320  rsp: 0x000000030522d310
r8: 0x0000000000002c00   r9: 0x0000000000000100  r10: 0x00000000000007fb  r11: 0x000000000000003f
r12: 0x00007fb54802e400  r13: 0x0004000000000000  r14: 0x00007fb51fc1b750  r15: 0x00007fb53f0ea200
rip:        rfl: 0x0000000000000242
tmp0: 0x000000010f6e3ddc tmp1: 0x000000010f6e3ddc tmp2: 0x000000010feb09c0
Binary Images:
0x10f6c0000 -        0x10f972fff _gerbview.kiface () <3ca5e8be-3eaa-32f5-985c-db00cce71394> /Volumes/VOLUME//kicad.app/Contents/PlugIns/_gerbview.kiface
0x1007d6000 -        0x100840fff org.kicad.gerbview ((5.1.12-1-10_14)) <981e76d7-ecef-3552-ba26-60a523e12bd4> /Volumes/VOLUME//kicad.app/Contents/Applications/gerbview.app/Contents/MacOS/gerbview
0x109d91000 -        0x10a79dfff libwx_osx_cocoau-3.0.0.4.0.dylib () <8b707308-25ca-3e72-a0df-ae707767e1bf> /Volumes/VOLUME//kicad.app/Contents/Frameworks/libwx_osx_cocoau-3.0.0.4.0.dylib
0x2009a1000 -        0x200a0cfff dyld ()  /usr/lib/dyld
0x7ff7ffc26000 -     0x7ff7ffc55fff runtime () <0ee8ce32-639c-316a-9551-dab9a2e0c8a5> /usr/libexec/rosetta/runtime
0x0 - 0xffffffffffffffff ??? () <00000000-0000-0000-0000-000000000000> ???
0x7ff81b60f000 -     0x7ff81b646fff libsystem_kernel.dylib () <61711d11-e776-3bc3-b9a2-6f9f37cb8499> /usr/lib/system/libsystem_kernel.dylib
0x7ff81b493000 -     0x7ff81b4d9fff libdispatch.dylib () <534511b9-b3b0-33a7-b1ea-402595d28bda> /usr/lib/system/libdispatch.dylib
0x7ff8247f7000 -     0x7ff824aeafff com.apple.HIToolbox (2.1.1) <04544f53-a387-3ac3-a85d-f8adfc0bc69e> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff81e048000 -     0x7ff81eed6fff com.apple.AppKit (6.9) <832ad371-d3b8-3061-b4e2-1c4e0cffce0b> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff81b647000 -     0x7ff81b652fff libsystem_pthread.dylib (*)  /usr/lib/system/libsystem_pthread.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.1G resident=0K(0%) swapped_out_or_unallocated=1.1G(100%)
Writable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)
                            VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Activity Tracing                   256K        1
ColorSync                          212K       24
CoreGraphics                         4K        1
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                           226.3M       36
MALLOC guard page                  192K       11
MALLOC_LARGE (reserved)           18.0M        1         reserved VM address space (unallocated)
MALLOC_MEDIUM (reserved)         480.0M        4         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
Rosetta Arena                     4096K        2
Rosetta Generic                    756K      186
Rosetta IndirectBranch             512K        1
Rosetta JIT                      128.0M        1
Rosetta Return Stack               120K       12
Rosetta Thread Context             120K       12
STACK GUARD                         16K        4
Stack                             10.6M        6
Stack Guard                       56.0M        2
VM_ALLOCATE                       8264K       14
VM_ALLOCATE (reserved)              72K       14         reserved VM address space (unallocated)
__CTF                               756        1
__DATA                            27.2M      377
__DATA_CONST                      19.4M      211
__DATA_DIRTY                       773K      125
__FONT_DATA                          4K        1
__LINKEDIT                       711.8M       29
__OBJC_RO                         82.7M        1
__OBJC_RW                         3200K        2
__TEXT                           387.0M      391
__UNICODE                          592K        1
dyld private memory               1024K        1
mapped file                        5.0G      547
shared memory                      800K       13
unshared pmap                     5504K        5
TOTAL                              7.5G     2040
TOTAL, minus reserved VM space     6.6G     2040
Full Report
{“app_name”:“gerbview”,“timestamp”:“2022-07-01 10:25:26.00 -0400”,“app_version”:"(5.1.12-1-10_14)",“slice_uuid”:“981e76d7-ecef-3552-ba26-60a523e12bd4”,“build_version”:"(5.1.12-1-10_14)",“platform”:1,“bundleID”:“org.kicad.gerbview”,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 12.4 (21F79)”,“incident_id”:“A0108FC6-DF94-47EE-AF49-51F601049823”,“name”:“gerbview”}
“uptime” : 35000,
“procLaunch” : “2022-07-01 10:25:25.3441 -0400”,
“procRole” : “Background”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookPro18,2”,
“procStartAbsTime” : 854614138453,
“coalitionID” : 801,
“osVersion” : {
“train” : “macOS 12.4”,
“build” : “21F79”,
“releaseType” : “User”
“captureTime” : “2022-07-01 10:25:26.3134 -0400”,
“incident” : “A0108FC6-DF94-47EE-AF49-51F601049823”,
“bug_type” : “309”,
“pid” : 3077,
“procExitAbsTime” : 854637332579,
“translated” : true,
“cpuType” : “X86-64”,
“procName” : “gerbview”,
“procPath” : “/Volumes/VOLUME//kicad.app/Contents/Applications/gerbview.app/Contents/MacOS/gerbview",
“bundleInfo” : {“CFBundleShortVersionString”:"(5.1.12-1-10_14)",“CFBundleVersion”:"(5.1.12-1-10_14)",“CFBundleIdentifier”:“org.kicad.gerbview”},
“storeInfo” : {“deviceIdentifierForVendor”:“FC0C45E8-631A-5BB9-A0E3-006EBEAF55BD”,“thirdParty”:true},
“parentProc” : “kicad”,
“parentPid” : 765,
“coalitionName” : “org.kicad.kicad”,
“crashReporterKey” : “29CDC03B-7E75-05C3-FC39-AB55FCBE1917”,
“responsiblePid” : 765,
“responsibleProc” : “kicad”,
“wakeTime” : 1681,
“sleepWakeUUID” : “76614752-02C9-4B3F-993B-A8819782D9DB”,
“sip” : “enabled”,
“vmRegionInfo” : “0 is not in any region.  Bytes before following region: 4303183872\n      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n—>  \n      __TEXT                      1007d6000-100841000    [  428K] r-x/rwx SM=COW  …acOS/gerbview”,
“isCorpse” : 1,
“exception” : {“codes”:“0x0000000000000001, 0x0000000000000000”,“rawCodes”:[1,0],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGSEGV”,“subtype”:“KERN_INVALID_ADDRESS at 0x0000000000000000”},
“termination” : {“flags”:0,“code”:11,“namespace”:“SIGNAL”,“indicator”:“Segmentation fault: 11”,“byProc”:“exc handler”,“byPid”:3077},
“vmregioninfo” : “0 is not in any region.  Bytes before following region: 4303183872\n      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n—>  \n      __TEXT                      1007d6000-100841000    [  428K] r-x/rwx SM=COW  …acOS/gerbview”,
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:186425,“threadState”:{“flavor”:“x86_THREAD_STATE”,“rbp”:{“value”:12971070240},“r12”:{“value”:140416573957120},“rosetta”:{“tmp2”:{“value”:4562028992},“tmp1”:{“value”:4553850332},“tmp0”:{“value”:4553850332}},“rbx”:{“value”:2},“r8”:{“value”:11264},“r15”:{“value”:140416423731712},“r10”:{“value”:2043},“rdx”:{“value”:0},“rdi”:{“value”:0},“r9”:{“value”:256},“r13”:{“value”:1125899906842624},“rflags”:{“value”:578},“rax”:{“value”:0},“rsp”:{“value”:12971070224},“r11”:{“value”:63},“rcx”:{“value”:3248525358},“r14”:{“value”:140415898597200},“rsi”:{“value”:6120}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:146913,“symbol”:“GERBVIEW_FRAME::OnUpdateSwitchCanvas(wxUpdateUIEvent&)”,“symbolLocation”:97,“imageIndex”:0},{“imageOffset”:233562,“symbol”:"GERBVIEW_FRAME::GERBVIEW_FRAME(KIWAY, wxWindow*)”,“symbolLocation”:4714,“imageIndex”:0},{“imageOffset”:19360,“symbol”:“GERBV::IFACE::CreateWindow(wxWindow*, int, KIWAY*, int)”,“symbolLocation”:48,“imageIndex”:0},{“imageOffset”:209921,“symbol”:“KIWAY::Player(FRAME_T, bool, wxTopLevelWindow*)”,“symbolLocation”:433,“imageIndex”:1},{“imageOffset”:22558,“symbol”:“PGM_SINGLE_TOP::OnPgmInit()”,“symbolLocation”:1102,“imageIndex”:1},{“imageOffset”:26219,“symbol”:“APP_SINGLE_TOP::OnInit()”,“symbolLocation”:123,“imageIndex”:1},{“imageOffset”:1262635,“symbol”:“wxApp::CallOnInit()”,“symbolLocation”:155,“imageIndex”:2},{“imageOffset”:490869,“symbol”:“wxEntry(int&, wchar_t**)”,“symbolLocation”:117,“imageIndex”:2},{“imageOffset”:21312,“symbol”:“main”,“symbolLocation”:48,“imageIndex”:1},{“imageOffset”:21790,“symbol”:“start”,“symbolLocation”:462,“imageIndex”:3}]},{“id”:186434,“name”:“com.apple.rosetta.exceptionserver”,“frames”:[{“imageOffset”:18884,“imageIndex”:4},{“imageOffset”:74848,“imageIndex”:4},{“imageOffset”:81624,“imageIndex”:4}]},{“id”:186464,“frames”:[{“imageOffset”:141332,“imageIndex”:4}]},{“id”:186465,“frames”:[{“imageOffset”:141332,“imageIndex”:4}]},{“id”:186466,“frames”:[{“imageOffset”:141332,“imageIndex”:4}]},{“id”:186467,“frames”:[{“imageOffset”:141332,“imageIndex”:4}]},{“id”:186470,“name”:“com.apple.NSEventThread”,“frames”:[{“imageOffset”:140706009868608,“imageIndex”:5},{“imageOffset”:6582,“symbol”:“semaphore_wait_trap”,“symbolLocation”:10,“imageIndex”:6},{“imageOffset”:14286,“symbol”:"_dispatch_sema4_wait",“symbolLocation”:16,“imageIndex”:7},{“imageOffset”:15517,“symbol”:"_dispatch_semaphore_wait_slow",“symbolLocation”:98,“imageIndex”:7},{“imageOffset”:278083,“symbol”:"_BeginEventReceiptOnThread",“symbolLocation”:159,“imageIndex”:8},{“imageOffset”:1756095,“symbol”:"_NSEventThread",“symbolLocation”:37,“imageIndex”:9},{“imageOffset”:25825,“symbol”:"_pthread_start",“symbolLocation”:125,“imageIndex”:10},{“imageOffset”:8043,“symbol”:“thread_start”,“symbolLocation”:15,“imageIndex”:10}]}],
“usedImages” : [
“source” : “P”,
“arch” : “x86_64”,
“base” : 4553703424,
“size” : 2830336,
“uuid” : “3ca5e8be-3eaa-32f5-985c-db00cce71394”,
“path” : “/Volumes/VOLUME//kicad.app/Contents/PlugIns/_gerbview.kiface",
“name” : “_gerbview.kiface”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4303183872,
“CFBundleShortVersionString” : “(5.1.12-1-10_14)”,
“CFBundleIdentifier” : “org.kicad.gerbview”,
“size” : 438272,
“uuid” : “981e76d7-ecef-3552-ba26-60a523e12bd4”,
“path” : "/Volumes/VOLUME//kicad.app/Contents/Applications/gerbview.app/Contents/MacOS/gerbview”,
“name” : “gerbview”,
“CFBundleVersion” : “(5.1.12-1-10_14)”
“source” : “P”,
“arch” : “x86_64”,
“base” : 4460187648,
“size” : 10539008,
“uuid” : “8b707308-25ca-3e72-a0df-ae707767e1bf”,
“path” : “/Volumes/VOLUME/*/kicad.app/Contents/Frameworks/libwx_osx_cocoau-3.0.0.4.0.dylib”,
“name” : “libwx_osx_cocoau-3.0.0.4.0.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 8600031232,
“size” : 442368,
“uuid” : “b70ce1ec-b902-3852-8268-05de00bfa8d5”,
“path” : “/usr/lib/dyld”,
“name” : “dyld”
“source” : “P”,
“arch” : “arm64”,
“base” : 140703124578304,
“size” : 196608,
“uuid” : “0ee8ce32-639c-316a-9551-dab9a2e0c8a5”,
“path” : “/usr/libexec/rosetta/runtime”,
“name” : “runtime”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703587954688,
“size” : 229376,
“uuid” : “61711d11-e776-3bc3-b9a2-6f9f37cb8499”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703586398208,
“size” : 290816,
“uuid” : “534511b9-b3b0-33a7-b1ea-402595d28bda”,
“path” : “/usr/lib/system/libdispatch.dylib”,
“name” : “libdispatch.dylib”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703740948480,
“CFBundleShortVersionString” : “2.1.1”,
“CFBundleIdentifier” : “com.apple.HIToolbox”,
“size” : 3096576,
“uuid” : “04544f53-a387-3ac3-a85d-f8adfc0bc69e”,
“path” : “/System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox”,
“name” : “HIToolbox”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703632228352,
“CFBundleShortVersionString” : “6.9”,
“CFBundleIdentifier” : “com.apple.AppKit”,
“size” : 15265792,
“uuid” : “832ad371-d3b8-3061-b4e2-1c4e0cffce0b”,
“path” : “/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit”,
“name” : “AppKit”,
“CFBundleVersion” : “2113.50.132”
“source” : “P”,
“arch” : “x86_64”,
“base” : 140703588184064,
“size” : 49152,
“uuid” : “bc574849-1aae-31e7-b350-916dda999d97”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“sharedCache” : {
“base” : 140703584927744,
“size” : 15220686848,
“uuid” : “53b6853f-0bc3-33f5-be72-1aca3a188ff8”
“vmSummary” : “ReadOnly portion of Libraries: Total=1.1G resident=0K(0%) swapped_out_or_unallocated=1.1G(100%)\nWritable regions: Total=1.2G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.2G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nActivity Tracing                   256K        1 \nColorSync                          212K       24 \nCoreGraphics                         4K        1 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                           226.3M       36 \nMALLOC guard page                  192K       11 \nMALLOC_LARGE (reserved)           18.0M        1         reserved VM address space (unallocated)\nMALLOC_MEDIUM (reserved)         480.0M        4         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nRosetta Arena                     4096K        2 \nRosetta Generic                    756K      186 \nRosetta IndirectBranch             512K        1 \nRosetta JIT                      128.0M        1 \nRosetta Return Stack               120K       12 \nRosetta Thread Context             120K       12 \nSTACK GUARD                         16K        4 \nStack                             10.6M        6 \nStack Guard                       56.0M        2 \nVM_ALLOCATE                       8264K       14 \nVM_ALLOCATE (reserved)              72K       14         reserved VM address space (unallocated)\n__CTF                               756        1 \n__DATA                            27.2M      377 \n__DATA_CONST                      19.4M      211 \n__DATA_DIRTY                       773K      125 \n__FONT_DATA                          4K        1 \n__LINKEDIT                       711.8M       29 \n__OBJC_RO                         82.7M        1 \n__OBJC_RW                         3200K        2 \n__TEXT                           387.0M      391 \n__UNICODE                          592K        1 \ndyld private memory               1024K        1 \nmapped file                        5.0G      547 \nshared memory                      800K       13 \nunshared pmap                     5504K        5 \n===========                     =======  ======= \nTOTAL                              7.5G     2040 \nTOTAL, minus reserved VM space     6.6G     2040 \n”,
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“trialInfo” : {
“rollouts” : [
“rolloutId” : “607844aa04477260f58a8077”,
“factorPackIds” : {
“SIRI_MORPHUN_ASSETS” : “6103050cbfe6dc472e1c982a”
“deploymentId” : 240000066
“rolloutId” : “60da5e84ab0ca017dace9abf”,
“factorPackIds” : {
  "deploymentId" : 240000008
“experiments” : [
Model: MacBookPro18,2, BootROM 7459.121.3, proc 10:8:2 processors, 64 GB, SMC
Graphics: Apple M1 Max, Apple M1 Max, Built-In
Display: Color LCD, 3456 x 2234 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5
AirPort: Wi-Fi, wl0: Apr  6 2022 05:55:54 version 20.90.45.0.8.7.118 FWID 01-e7138ff2
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
