I have finished my PCB board layout and plotted gerber files but my edge cuts layer doesn’t show up as a gerber file. I have it selected in the plot window and the board outline (graphic lines) is definitely there on the Edge.cuts layer in Pcbnew. Is there something I am missing? The board outline is a 1.75 by 2.25 rectangle. Thanks,
Plot has some strange default settings. Edge cuts and mask layers have to be enabled. Also watch out for the additional copper layers on multilayers
Those are pretty standard settings I use (don’t need device references on the board).
PS: I suggest to use a dedicated gerber sub-folder for easier overview of the gerber files (like you can see in the screenshot) for zipping and sending to the fab.
Thank you Joan. That explicit reply was helpful. I was able to create the Edge.Cuts gerber file. It was the Gerber Options two checkmarks that made the difference.
