Is it possible to make settings for the layer manager so that I, as a user, can determine the color and position of the layer myself? So that the next time you load files, the layers are arranged in the same order as it was set in the settings.
Currently the layers are in this order:
copper
mask
paste
silkscreen
I would like to set up this arrangement of layers for myself:
I changed the position of the layers as I like. In this form, I can immediately see the layers as they will be after the board is produced.
Unfortunately, when moving layers, the layer colors do not move and you have to adjust them anew.
Therefore, when checking a project, I have to first move the layers and then change the color. If an error occurs, I download the files again and repeat these operations.
I would really like to be able to customize the arrangement of layers and colors for the user.
Maybe someone knows how to set this up?
Thank you.
But itâs very simple. Itâs 60 âgraphics layersâ and some colors for special items. Just over a year ago I wrote:
It would be nice if the gerber layers had the same color theme as the PCB Editor. (Or itâs own settable theme with defaults the same as the PCB editor).
Layer manager â select layer , right click â move layer up/down (or +/-).
The only annoying thing is that the the layer doesnât bring the assigned color down/up when it moves;
the color is associated to the âlevelâ not to the layer.
Hello. Thanks everyone for your help. I found the answer.
In KiĐĄad 7 and 8 I found the XOR mode button in the gerber viewer, this is what I need.
Only for proper viewing you need to first open the layers, and then the holes, so that the holes are at the bottom of the list. Then the board looks like it would have looked like after manufacturing.
I discovered the same problem that in the gerber viewer the associated color to a layer does not move when changing the layer order with UP and DOWN. To me this seems to be a bug and maybe somebody could create a bug report. Iâm new to KiCad and not familiar with that procedure yet.
If it is intended that the colour isnât linked to the layer I would recommend a configurable option so that the user could decide which behaviour he/she would prefer.
