Gerber viewer export to pcb editor
HI ,
i have a problem with gerber view, when i export it to pcb editor,
some pads transform, from rectangular to oval.
Sto usando:
Application: KiCad (64-bit)
Version: (6.0.8), release build
wxWidgets 3.1.7
libcurl/7.83.1-DEV Schannel zlib/1.2.12
Date: Sep 29 2022 00:21:26
wxWidgets: 3.1.7 (wchar_t,wx containers)
Boost: 1.79.0
OCC: 7.6.0
Curl: 7.83.1-DEV
ngspice: 37
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
how do i go about solving it…
Thank you
6.0.8 is too old, 6.0.11 is the latest in the old (and unsupported!) 6 series. Because you are using Windows you should also be able to update to the latest v7.
i tried but not solve …
Application: Editor di C.S. KiCad (64-bit)
Version: (6.0.11), release build
wxWidgets 3.2.1
libcurl/7.83.1-DEV Schannel zlib/1.2.13
Date: Jan 26 2023 07:02:30
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.83.1-DEV
ngspice: 38
Compiler: Visual C++ 1934 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
