I am sure I am in the wrong place but I have to ask somewhere.
The problem is, that in my Gerber viewer all the layers look exactly the same for both sides of my board, the only layer where there is a difference is the drill hole layer where I can at least see the drill hole markers.
So how do I fix this problem??
Yaaa this was exactly the problem I found it while trying to make a gerber file with each layer on at a time.
Thank you very much for your very prompt reply.
