I created a filled zone in my project to act as a ground plane. I believe it worked properly and I did what I was supposed to and assigned the correct layer, but it seems like when I plot the Gerber and drill files, the Gerber preview shows the plane almost as a silkscreen rectangle. Below are some images confirming what is happening. I’m not exactly sure what could be causing this however it is my first time using these filled zones.
I feel like I’m missing some simple menu setting or something, but I can’t figure it out. Any help would be appreciated.
