So I created an empty project in KiCad-nightly V5.99, created gerbers and loaded an “empty” gerber layer in a text editor.
The files of the empty layers are between 522 and 527 bytes in size:
paul@medion:~/projects/kicad/LED_PT4115_599/empty/gerber$ ls -hl
total 48K
-rw-rw-r-- 1 paul paul 526 Dec 1 21:56 empty-B_Cu.gbr
-rw-rw-r-- 1 paul paul 527 Dec 1 21:56 empty-B_Mask.gbr
-rw-rw-r-- 1 paul paul 522 Dec 1 21:56 empty-B_Paste.gbr
-rw-rw-r-- 1 paul paul 523 Dec 1 21:56 empty-B_Silkscreen.gbr
-rw-rw-r-- 1 paul paul 752 Dec 1 21:56 empty-Edge_Cuts.gbr
-rw-rw-r-- 1 paul paul 526 Dec 1 21:56 empty-F_Cu.gbr
-rw-rw-r-- 1 paul paul 527 Dec 1 21:56 empty-F_Mask.gbr
-rw-rw-r-- 1 paul paul 522 Dec 1 21:56 empty-F_Paste.gbr
-rw-rw-r-- 1 paul paul 523 Dec 1 21:56 empty-F_Silkscreen.gbr
-rw-rw-r-- 1 paul paul 2,5K Dec 1 21:56 empty-job.gbrjob
And when opening such a file it does end with a "M02* line:
%TF.GenerationSoftware,KiCad,Pcbnew,5.99.0-unknown-a3e8e0184~106~ubuntu20.04.1*%
%TF.CreationDate,2020-12-01T21:56:27+01:00*%
%TF.ProjectId,empty,656d7074-792e-46b6-9963-61645f706362,rev?*%
%TF.SameCoordinates,Original*%
%TF.FileFunction,Legend,Top*%
%TF.FilePolarity,Positive*%
%FSLAX46Y46*%
G04 Gerber Fmt 4.6, Leading zero omitted, Abs format (unit mm)*
G04 Created by KiCad (PCBNEW 5.99.0-unknown-a3e8e0184~106~ubuntu20.04.1) date 2020-12-01 21:56:27*
%MOMM*%
%LPD*%
G01*
G04 APERTURE LIST*
G04 APERTURE END LIST*
M02*
Which means my detailism is satisfied and I see no need to make an issue out of it on gitlab.
You are quite right, I re-downloaded the Silk and it is not empty. When I downloaded it the first time, the result was empty. Why that is I don’t know, I can only speculate.
Both the Silk I have now and the empty silk you created look perfect, as usual with KiCad Gerbers.
I notice you have not ticked “Use extended X2 format” when you generate GERBER.
Gerber-X2 is really good and I would advocate this being the default.
Gerber-X1 files should still be valid but lets entertain the concept that there is a bug.
X2 format files are still not accepted by a number of manufacturers (yeah, I know). I still use X1 with protel extensions for maximum compatibility for this reason. Has nothing to do with this issue though.
