I have selected Imperial units in my project (GeneralSettings) and my drill file settings are set for imperial but my Gerber files get generated us mm, can I get my gerbers in imperal unit.
(sorry if this is not the correct way to include screen shots)
This is what my gbr file says:
%FSLAX45Y45*%
G04 Gerber Fmt 4.5, Leading zero omitted, Abs format (unit mm)*
I am using a milling machine to build the board and the drill file is way off from the pcb.
I am using
Version: 5.0.2-bee76a0~70~ubuntu18.04.1, release build
How o I tell KiCad to generate all the plot files using imperial units.
Thank you
