I’m running into a bit of an issue with the Gerber files generated from within PCBNew.
If youtake a look at my soldermask layer (from within PCBNew), you can tell the soldermasks for the ICs on the board are not touching.
However if you take a look at the soldermask layer Gerber file, all the soldermasks for eachside of each IC, are touching, so the soldermask belonging to the ICs look like long rectangles.
Pcp_new does not check for soldermask minimum width. This is only checked during the gerber export. That step then removes soldemask where it would violate that.
Check your board setup against your manufacturers requirements to see if you can doe something about that.
For more detailed help with that step you really need to tell us your kicad version as the user interface did change a bit between version.
Thank you for the insight. I’m currently using KiCad 5.0.0.
I would appreciate more detailed help with how to adjust the board’s minimum soldermask width. Do you think the problem in this case is that my minimum soldermask width is set to a value that is too high?
The kicad default settings are a bit on the safe side. There is a high chance that your manufacturer can produce boards with lower soldermask clearances and also lower minimum soldermask width.
All of this is controlled under setup->pads and mask clearance.
