A lot of the PCB fab houses want all the filenames to be the same but with Protel extensions. If I plot the Gerbers with the Protel extensions options checked I do get the desired Protel extensions, but the names all end with an abbreviation of the layer name, eg - MyProject-F,SilkS.gto, Renaming the files is not the end of the world, but is there a way to get the export with just the project name as the name part? Or is this an enhancement request for an option to provide “clean” names?
I’m on Windows, if it matters, and am still running 4.x
Apologies in advance if this feature has already been added to 5.x
But it gets very, very tedious when you make many small boards one after one, many versions, and after every one of them you have to rename the gerber files. I have used AntRenamer. I could use a KiCad feature where I could construct the file names like this:
I would need especially layer names like F_Cu instead of F.Cu. It’s so infuriating that e.g. gmail doesn’t accept file names with several dots in attachements.
That may sneak the file past the email security filter, but you run the risk of confusing the recipient. Or, he may get annoyed when he double-clicks on the attachment and gets the dialog about “Unknown file type. What do you want the computer to do with this strange file?”.
