Gerber File Output
Hi all,
Can anyone help me with the file formats of the generated files when I create gerbers?
In one example, I plotted my project in PCB view, and I get files with the filetypes:
.gbl, .gbs, .gbo, .gm1, .gtl, .gto.
In a different project, I get all the same filenames, but the file types are all .gbr.
Any ideas?
Thanks
The difference very likely is:
Pcbnew / File / Plot / (Plotformat: Gerber ) Gerber Options: / Use Protel filename extensions.
Hi paulvdh,
You are correct! Thank You - I should have seen that option…
