I am trying to create several buses on eeschema, running 5.1.4-0, and I can’t find a way to generate an [Insert] on the Macbook Pro keyboard to create successive labels D0 (sure, easy enough) but then you are supposed to easily use [Insert] to create more D1, D2, etc. on the pads below the starting pad.
Of course my Mac (running 10.13.6) does not have an [Insert] key…serious online searching didn’t help.
So I tried Karabiner - no joy there either. Pretty sure I set Karabiner up correctly…yup the Eventviewer says an [Insert] is being generated.
Is it possible the OSX/MAC build did not include [Insert]??
clutching at straws here, can’t believe I am the only person experiencing this - perhaps if I just RTFM some more…
Are you sure you are on version 5.1.4? doulbe check under help -> about kicad. (all version 5.1.x builds should have the preference dialog as i describe it above. What you describe is how 5.0.x looked like)
I can confirm, Kicad 5.1.4 on OSX has two places called “Preferences”: one in the Kicad menu (next to the Apple menu), and one menu called Preferences (which contains Manage Symbol/FP Library, Configure Paths, Set Language, and Toolset (graphics) selection). It’s a point of confusion for sure!
